Has this ever happened to you?
Old Oct 24, 2002 | 12:32 AM
Timothy2468's Avatar
Timothy2468
Default Has this ever happened to you?
I have a 99' coupe. I hit what I thought was a pothole and the D.I.C. starts flashing something like " check ABS system" . Something to do with the anti-lock brake system. I pressed reset to no avail. It went away when I started up again. Should I be concerned? Thanks.
Old Oct 24, 2002 | 01:18 AM
DsC5's Avatar
DsC5
Default Re: Has this ever happened to you? (Timothy2468)
edit - my answer was wrong, I was thinking about something else. :seeya
[Modified by DsC5, 12:51 AM 10/24/2002]
Old Oct 24, 2002 | 01:38 AM
Moundir's Avatar
Moundir
that's normal, if it goes away :yesnod: You will also get that message after a nice long burnout :D
Old Oct 24, 2002 | 05:28 PM
QwikSilvr's Avatar
QwikSilvr
Default Re: Has this ever happened to you? (Moundir)
What he said. Happens to me occasionally. It's no biggie. You can go into into diagnostic mode to pull your codes and actually reset it just after it happens.
To Has this ever happened to you?
