Need sway bar information
Old Oct 23, 2002 | 05:36 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Need sway bar information
Does anybody know the sizes of base bars, Z-51 bars and z06b bars? Front and rear. Any help will be appreciated!!!!!
Old Oct 23, 2002 | 08:10 PM
DI2FLY's Avatar
DI2FLY
Default Re: Need sway bar information (NEED FOR SPEED)
I was told the early 99 Z51 bars are both smaller than the ZO6 bars.
That was the case with mine., and I was shown the difference.
Old Oct 23, 2002 | 11:58 PM
NEED FOR SPEED
St. Jude Donor '07
Default Re: Need sway bar information (DI2FLY)
ttt
Old Oct 24, 2002 | 02:36 PM
Mr. C's 5's Avatar
Mr. C's 5
The standard FE1 suspension has 23.1mm front and 19.1 mm rear sway bars. The swaybar dimensions of the 97 - 99 Z51 suspension are 25.4 mm diameter in front, 21.7 mm rear. Plastic end links were used all around. For 2000 2001, they were changed to 28.6 mm front, 23.6 rear and steel end links in front only. In 2002, aluminum links were used in all four corners. The Z06 (FE4) uses a hollow 30mm front and the same 23.6 rear with aluminum links all around. Hope this helps. - C.
To Need sway bar information
