Blowing Fuse
Old Aug 20, 2018 | 07:09 PM
VETTEC599's Avatar
VETTEC599
Default Blowing Fuse
My back-up camera is spliced into my back-up lights. This works quite well except I blew the fuse - 10 amp - in the fuse box under the passenger side carpet. Was told to replace with a 15 amp - blew that as well! Am I looking for trouble if I go higher than 15 amp? I am more annoyed about not having my camera and having to crawl under the dash than anything else! I have the same setup in my other car with no problem! Can I go higher than 15 amp OR should I just live with it! The 10 amp blew several weeks after the install - the 15 amp lasted several months.
Old Aug 20, 2018 | 08:36 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I myself wouldn’t go higher than 10 amps...that’s what that
back up light circuit was engineered for...how many amps does the back up camera draw ???...if you went higher the correct way would be to go with a heavier gauge wire on that whole circuit...see what’s all on that circuit...maybe convert your back up lights if they are incandescent to LED !!...they draw less current !!!
Old Aug 21, 2018 | 09:44 AM
Grandpa1's Avatar
Grandpa1
Yep. Might cause a fire. Probably need to put one of them on another circuit.
Old Aug 21, 2018 | 12:55 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by grandpa1
yep. Might cause a fire. Probably need to put one of them on another circuit.
agree...1,000 % !!!
Old Aug 21, 2018 | 01:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Man, I bet ya that back up camera only draws 5 AMPS (if that).
Brother, YOU HAVE A SHORT CIRCUIT! That means it could turn into Smoke, fire, flames if you keep adding bigger fuses. Hell, just bridge the fuse with a finishing nail. That pesky fuse will never pop again!!!
You need to figure out where the positive and negative wire are having a party!!
Could be at the connection at the camera, somewhere the wires pass through the body, Positive wire to chassis ground (rub through) ect....
BC
Old Aug 21, 2018 | 04:29 PM
Tsumi's Avatar
Tsumi
Do you have an automatic or manual? If manual, your reverse switch may have gone bad. One of the symptoms of a bad manual reverse switch is blowing the reverse light fuse.
Old Aug 22, 2018 | 01:20 AM
GCG's Avatar
GCG
Originally Posted by VETTEC599
My back-up camera is spliced into my back-up lights. This works quite well except I blew the fuse - 10 amp - in the fuse box under the passenger side carpet. Was told to replace with a 15 amp - blew that as well! Am I looking for trouble if I go higher than 15 amp?...
You should find the source of your short circuit, as mentioned above, and go back to the original 10A fuse.
If you are using 1157 OEM backup light bulbs they draw 4.2A (2.1A x 2) and your camera shouldn't be drawing more than 100mA (or no more than 500 or 600 mA if it has built-in LEDs for low light conditions). So, rounding off, your total current should be no more than 5A. You shouldn't increase the fuse.
To Blowing Fuse
