measuring clutchwear
SO, You having a stock LS-1 clutch, I can assure you that it will NOT be happy under any hard launching (regardless of mileage or wear). Just understand that your stock clutch will need to be replaced with something that will handle the additional TORQUE that your forced induction engine will feed it!
I went with a TICK Master, new GM Slave, SPEC Dual Disk Clutch, New GM pilot bearing, new GM throw out bearing and a remote bleeder..
Several aftermarket companies make a better GM Slave Cylinder center cylinder that the throw-out bearing rides on.. The OEM one is plastic and can melt. The aftermarket is machined aluminum.
There is NO WAY to really check out the condition of the flywheel, pressure plate and disk with out system removal. You can measure the disk AIR GAP if you remove the bell housing lower inspection cover.
Bill
Bill
I know I'm on borrowed time, but I've also read in here about some that have survived with stock clutch for several 1000 miles. A clutch change is easily 2000 $, so if I can push it forward...
I'm just below 500 whp and above 450 wtq, so no crazy power...
