C5 Selective Real Time Damping.
Old Sep 13, 2018 | 08:54 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Originally Posted by 8VETTE7
Both systems use electronics to control the damping of the shocks. The F45 has valving in the shocks and the F55 uses a special fluid containing magnetic particles that are aligned in specific orientation by the electronics to accomplish the changes in damping. Three switch settings on F45 and only two switch settings on F55 on the center console. Both are extremely expensive to replace the shocks when they wear out. Expect to pay north of $2000 for the shocks alone plus installation if you don't do your own work. Conventional shocks go for $300 to $400 for all 4 shocks plus installation. You cannot just replace the shocks without some way to fool the computer.
Rock Auto runs specials (one running now) on the shocks and they can be had for a little less than that, but you're right, they're still pretty pricey. Question is, does a guy need all 4?
I would generally agree that the best approach for disabling the F45 suspension option is to remove it from the BCM as an RPO. However, not all C5 owners with cars equipped with RPO F45 have the availability of obtaining access to a Tech II to be able to remove the RPO from the BCM. For those people the resistor or Simm option is available as a viable alternative. While there are some reports of problems with the resistors or Simms over time, they are not wide spread based on what I have seen/read on this forum.
With so many forum members owning one now, myself included, it would be pretty easy to take a weekend road trip to where ever you could find an agreeable member and do something like this for the price of some gas and perhaps a beer. I bought a T2 when they were even more than they are today and never gave that a second thought at $350. Now they're under $280 shipped, pretty much a no-brainer for a DIYer kinda C5 owner.
As a side note. I just went from a Z51 C5 w/completely rebuilt suspension (including urethane) to a Mag Ride C6. Saying the difference is night and day doesn't do it justice. I can't speak to the ride quality of the C5 F45/55 suspensions, but the Mag Ride is amazing. Mine basically never leaves tour and it rides like a Cadillac. Wheew...
Old Nov 11, 2024 | 02:27 PM
Keyman57's Avatar
Keyman57
Default What Tech2 knockoff ? Did you get? Anyone in Phoenix?
So far, the knock offs on Amazon that I found will not do real time damping in RPO deletion of the*I have a 2004, so I have F 55.
Do you have to plug the shocks back in to remove the RPO real time damping ?
?I have the original GM shocks in a box.
