Old Sep 1, 2018 | 12:57 PM
Thomas Sousa's Avatar
Thomas Sousa
1st Gear
Default 04
I recently bought a 04 convertible w 350 .had overheating issues back to dealer 3 days .then back to dealer w wet front floor was hose clog / also at same time experiencing no power at times and traction lights and abs lights comming on .after 3 weeks got her back yesterday ran like a dream today service traction and abs bought the car for 20 from a dealer who claims he wants to make it right .any clue as to what's wrong here
Old Sep 1, 2018 | 01:07 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Congrats and welcome to the forum Thomas.
Post your questions in the C5 section. Plenty of knowledgeable folks over there.
Good Luck!!
https://www.corvetteforum.com/forums/c5-tech-1/
Old Sep 1, 2018 | 01:34 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum, Thomas, and congratulations on your C5!
First suggestion is to pull and post your codes in the C5 Tech section at https://www.corvetteforum.com/forums/c5-tech-1/.
If you don't know how to pull your codes, check this link: http://www.stengel.net/diccodes.htm
You'll quickly learn that the DIC codes will be your great starting point for many of the issues you may face with your C5 over the years. This doesn't mean you'll have lots of problems, but when you do have problems, the DIC codes will always be a good starting point.
Best wishes with this! Larry (Route99)
Old Sep 1, 2018 | 04:40 PM
jehuds10's Avatar
jehuds10
Congrats and welcome to the forum!
Old Sep 1, 2018 | 05:54 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
Congrats. on your C5!
Best of luck getting the issues sorted out.
Old Sep 1, 2018 | 06:19 PM
Moved to C5 Tech.
Old Sep 2, 2018 | 12:36 AM
BigGun's Avatar
BigGun
The DIC codes will tell you what you where the problem lies. Hope the dealer is dong this under warranty. The repair could be simple or very expensive.
Old Sep 2, 2018 | 08:03 AM
tmd442's Avatar
tmd442
Welcome,
When I first saw your name I freaked out a little.
Good luck with the car.
To 04
