Hey Rob, I was told there was a reverse flow check valve built in the fuel pump, is there another check valve built in the fuel feed line ?
Hi !!
Since the pump and fuel filter/ pressure regulator were changed I crossed those 2 items out...so it's either an injector or the feed line check valve leaking...maybe I shouldn't !!!
Hi !!
Hey Rob, the car is not my daily driver and it does sit a lot. Thanks for all the info and I appreciate the opportunity of you letting me borrow your adapter, I’ll give you a heads up when you return if I need use it, I just need to find out if there is another check valve other then the one built in the fuel pump. Do you come down this way for corvette weekend at the beach Oct 12-13 ?
Back in town !!...don't know if you continued to diagnose the fuel pressure issue...if you still need the adapters let me know !!
