Driver side Blend Door Actuator HELP
Old Sep 14, 2018 | 01:54 PM
jandmenter's Avatar
jandmenter
Default Driver side Blend Door Actuator HELP
Driver side Blend Door Actuator. Will I need to pull the dash to replace?
Old Sep 14, 2018 | 02:50 PM
v6turbo87's Avatar
v6turbo87
Yes
Old Sep 14, 2018 | 03:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you can cram your self into the drivers foot well, you can access that one from under the dash. I'm fat so I remove the seat and lay in the foot well with my legs sticking into the rear compartment.. FORGET ABOUT doing that on the passengers side. The dash MUST come off.
Old Sep 14, 2018 | 03:40 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yes....I don't care what anyone says I couldn't get my hand up there and even if I could NFW I would have been able to do the job like that...dash removal is not that hard and if you are gonna replace one just do both
Old Sep 14, 2018 | 03:53 PM
huesmann's Avatar
huesmann
I think I could have got my hand up there under the dash. But I couldn't have done any actual work there with it.
It's way easier to just remove the dash pad—maybe an hours worth of work, if that.
Old Sep 14, 2018 | 05:25 PM
jandmenter's Avatar
jandmenter
Sweet Thanks everyone..
Old May 18, 2021 | 01:49 AM
rfchapie's Avatar
rfchapie
Hi,
I have a 98 that does not have dual climate control. Pretty sure the actuator is going out. It was blowing hot, but I played around with the temperature **** and heard a clicking sound, I finally got it blowing cold air. Since I do not have dual climate is my actuator on the drivers side and can I get to it from the footwell?
Old May 18, 2021 | 03:56 PM
SilverC54me's Avatar
SilverC54me
Don't remember which side it is on for the manual HVAC but it is definitely a different part number than the dual zone.
Gary
Old May 29, 2021 | 02:34 AM
IronMaidens2.0's Avatar
IronMaidens2.0
Originally Posted by rfchapie
Hi,
I have a 98 and I need to know which set I have . Now I wonder because if I turn my passengers temp **** I don't see anything showing any type of change..I am having issues with actuator on driver side also .Done reset a bunch of times works fine for a day or two then SOS.
To Driver side Blend Door Actuator HELP
