Priming fuel pump help please
Old Sep 15, 2018 | 08:48 AM
ascastil's Avatar
ascastil
Default Priming fuel pump help please
Hey everyone. I've got my car completely torn apart, heads are off, rear is dropped, tank out etc. I want to prime my fuel system to check for leaks before I bolt the backend all together. How can I go about doing this? I hooked up the battery and turned the key to on position and I didn't here anything. Not sure if that's the way to do it.
Old Sep 15, 2018 | 09:02 AM
ascastil's Avatar
ascastil
Ok I got it to prime, harness near tranny was unplugged. Any way to keep the pump running/system under pressure for a few minutes to check for leaks? Obviously it's a pita to pull back apart if leaking. I'm worried about those lines in the crossover tube mostly, it was real hard to see what was going on up there.
Old Sep 15, 2018 | 09:32 AM
ascastil's Avatar
ascastil
Ok I got it. Jumped the relay. Crossover tube seems a little cool. Just gonna undo that crossover and see if there is fuel in it. If not, good to go.
Old Sep 15, 2018 | 09:45 AM
ascastil's Avatar
ascastil
So if I pulled that crossover tube out a little and nothing came out. Good to go i guess?
To Priming fuel pump help please
