service column lock
Old Sep 16, 2018 | 04:20 PM
radc5's Avatar
radc5
Default service column lock
When I start the car service column lock appears, it does not shut off or lock up but the message is annoying. Do I have to install a LMC5 kit to clear this problem ?
Old Sep 16, 2018 | 04:34 PM
Andrew's Avatar
Andrew
Yes, install and put that message and problem behind you!
Old Sep 16, 2018 | 04:59 PM
rrwirsi's Avatar
rrwirsi
And when you do, also do the optional Brown Wire procedure found on page 2. Many cars still have message 'Pull Key' appear after installing w/o the Brown Wire procedure. Do it, and it will not appear.
To service column lock
