Error Codes
Old Sep 19, 2018 | 06:27 PM
omerparizkyc5's Avatar
omerparizkyc5
1st Gear
Default Error Codes
Hello everybody,
I received the following error codes on my dash,
I was wondering if anybody knows how I can fix this and not just erase them, as i can not figure out exactly what the codes mean from their description the codes are:
B2265 H - Horizontal Position Sensor Fault
U1064 H - Loss of Communications with BCM
P0102 H C - Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0412 H C - AIR Solenoid Relay Control Circuit
P0418 H C - AIR Pump Relay Control Circuit
P0704 H C - Clutch Switch Circuit (M/T)
P0801 H - Reverse Inhibit Solenoid Control Circuit (M/T)
P0803 H C - 1-4 Upshift Solenoid Control Circuit (M/T)
thanks in advance
Old Sep 19, 2018 | 07:38 PM
JR-01's Avatar
JR-01
Low voltage can cause multiple error codes. How is your battery? If it is old and weak I would start there. Clean and tight terminals?
Old Sep 19, 2018 | 09:55 PM
Moved to C5 Tech.
Old Sep 20, 2018 | 07:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Sep 20, 2018 | 11:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree that you should make sure that the battery has the proper CCA and reserve capacity. You also need to clear the DTCs and see what ones come back.
BC
To Error Codes
