what are these connectors?
Old Sep 20, 2018 | 03:30 PM
acroy's Avatar
acroy
Default what are these connectors?
new to me 2004 Z06 with transplanted Ls2. Going through the car, finding a few question marks. Assistance appreciated!!
#1:
empty 2-wire female plug near the horns, passenger side
#2:
empty 2-conductor male plug, drivers side in front of the radiator. This plug and connector #3 (below) are run together in wire loom under the front crossmember
#3:
capped small vacuum line, run in the same place as #2
Final pic showing #2 and #3 together coming out of the factory-looking wire loom
Old Sep 20, 2018 | 03:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! Looks like someone disconnected and REMOVED the A.I.R. (Air Injection Reaction) pump motor and air valve assy from that location. If you are NOT getting any DTCs, its also been TUNED to not report. Recommend that you SEAL up the electrical connector so it can not get any water /moisture in it.
Pounder's Avatar
Pounder
1/4 mile/AutoX
the first ones look to be for the air pump along with the vacuum line, which they discarded, the second not sure of your discription, my guess the hood light ???
Pounder's Avatar
Pounder
1/4 mile/AutoX
Bill was quicker on the draw !!!!
Old Sep 20, 2018 | 03:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LS2 can NOT use that AIR System.. So,, its been removed as a weight / space savings. Not a bad thing.
BC
Old Sep 20, 2018 | 04:16 PM
acroy's Avatar
acroy
Awesome! I will seal up the connections; possibly remove the wiring/vac line entirely to make it clean.
The C5 came with an under hood light? do tell. neither of my cars have had them.
THANKS!
Old Sep 20, 2018 | 04:29 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have an aftermarket hood???? Most aftermarket hoods don't have a place to mount that light but YES, ALL C5s should have a hood light on the passengers side of the hood.
BC
Old Sep 21, 2018 | 08:52 AM
acroy's Avatar
acroy
No sir, stock hood. However the sound insulation etc was removed, the underside is painted body color, PO kept it extremely clean and waxed. The car was a 'show' car. I suspect the light was removed at that time.
Ya'll are extremely helpful, thanks, this is a big benefit of Vette ownership!
To what are these connectors?
