Check engine light question...
Old Sep 21, 2018 | 03:50 PM
Hammer99's Avatar
Hammer99
Default Check engine light question...
While driving my 99 coupe today the check engine light came on, and it began running rough.
Turned out to be a plug wire came loose.
Running fine now but the damn check engine light is still on.
Anyone know how to re-set that?
Old Sep 21, 2018 | 04:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
clear the code
Old Sep 21, 2018 | 04:42 PM
Hammer99's Avatar
Hammer99
Originally Posted by pewter99
clear the code
OK, thank you. Somewhere in my archives I have those instructions.
Old Sep 21, 2018 | 05:47 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
https://www.corvetteforum.com/forums...-my-codes.html
Old Sep 21, 2018 | 07:23 PM
Moved to C5 Tech.
Old Sep 22, 2018 | 08:30 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I seem to recall that once a problem is corrected, even if you don't manually clear the code, it will go away after the car has cycled through a specific number of start, run, complete cool down, start, run, complete cool down cycles....
To Check engine light question...
