99 c5 V code abs edcm test
Old Sep 23, 2018 | 09:12 PM
Buzinsmd's Avatar
Buzinsmd
Default 99 c5 V code abs edcm test
Anyone know if theres a way to test an ebcm outside of the car? Could a salvage yard?
Old Sep 24, 2018 | 12:52 PM
lionelhutz's Avatar
lionelhutz
Not fully, no.
Old Sep 24, 2018 | 03:40 PM
Buzinsmd's Avatar
Buzinsmd
THanks for the reply
Old Sep 24, 2018 | 04:11 PM
Bill Dearborn's Avatar
Bill Dearborn
No way to check as they can't duplicate all of the input signals required and can't monitor any of the output signals. The only way to check is to install and use them to find out if they work.
Bill
Old Sep 24, 2018 | 04:46 PM
Buzinsmd's Avatar
Buzinsmd
Thanks for the reply!
Old Sep 25, 2018 | 10:56 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% agree..
BC
Old Sep 25, 2018 | 11:26 AM
wallysolvette's Avatar
wallysolvette
Most likely the fluid is dirty. Jack the rear up, put jack stands under trailing arms. Start engine and run it about 5 mph for 5 seconds. Let cool 30 seconds Do it again. This makes the ebcm work and run fluid through as front wheels are dstoped. Worked for me.
Old Sep 25, 2018 | 12:32 PM
Buzinsmd's Avatar
Buzinsmd
Good idea.
To 99 c5 V code abs edcm test
