C5 trouble starting
Old Sep 24, 2018 | 01:58 PM
Paul Whelan's Avatar
Paul Whelan
1st Gear
Default C5 trouble starting
Hi I have a 1998 C5 and the battery has been tested ok new alternator. I go to start the car with a battery that reads 12.6 starts ok let it warm up measure voltage while running on battery posts 14.1 turn car off battery voltage down to 12.2 and will barley turn over and wont start. Put battery charger back on to get back to 12.6 and do the same thing all over again. Any ideas???
Old Sep 24, 2018 | 02:45 PM
tentuna's Avatar
tentuna
Sounds like a weak battery should be 12.5V after running a while, take the battery out and have it load tested, I think you will find out it's not holding a charge.
Old Sep 24, 2018 | 02:57 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
To C5 trouble starting
