High idle problems
Old Oct 3, 2018 | 03:14 PM
Bluefire's Avatar
Bluefire
Originally Posted by cj28000
The car idles pretty good and runs great. Its just sometimes when come to a stop it either takes a few seconds for the idle to go to normal from around 1500 rpm or it will constantly stay at around 2000 rpm. I am going to check for vacuum leaks soon when I get the time, if I don't find any I will likely take it to a shop.
If you car is in Neutral (Rolling) or the clutch is depressed (Rolling) and the Idle hangs, the Throttle Cracker Airflow adder is too high. If the RPM's are not falling fast enough, double the number (x2) in the 0 - 8 MPH columns in the Throttle Follower table (bigger number makes it fall faster).
