C5 Power Seat Issue
Old Oct 1, 2018 | 07:24 PM
ron 97's Avatar
ron 97
5th Gear
Default C5 Power Seat Issue
I have a 97 with a drivers side power seat issue. Before buying the car the motors for the power seat were replace however the switch that is used to move the seat forward and backward is intermittent. By that I mean it will move at times an inch or two but not continues, After it reaches a certain point moving forward it works fine, It also works fine to move the seat backwards.. I want to believe it is a bad switch but before spending the money thought I would post this to see if anyone has or had a similar issue and how it was solved. Thanks
Old Oct 1, 2018 | 10:39 PM
Moved to C5 Tech.
