Engine not running since changing water pump
Old Oct 13, 2018 | 12:45 PM
  #41
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
We know the Control Feed is good !!...did you check 85 with test light connected to battery positive or ohm out 85 to a clean engine ground...I have a pic of 105... having trouble uploading it !!
Old Oct 13, 2018 | 12:51 PM
  #42
C5 Diag's Avatar
C5 Diag
G105 !!
Old Oct 13, 2018 | 12:53 PM
  #43
C5 Diag's Avatar
C5 Diag
how much exactly ????
Old Oct 13, 2018 | 01:00 PM
  #44
C5 Diag's Avatar
C5 Diag
With test between 85 and ground !!!...did you try this ???
Old Oct 13, 2018 | 01:33 PM
  #45
roppa440's Avatar
roppa440
While you were posting those pictures I went back and re-measured the ground. I had 0.29 ohm on the continuity setting of my meter. But then I thought to switch it to the 200 ohms range and got 12.4 ohms.
So I googled that G105 ground on my phone and saw it goes to the driver side of the block. I found one end on a strap on the inner fender under the brake booster.
I took the nut off. It looked OK. I went right through all the grounds when I bought the car about 6 years ago. But I gave it a clean anyway.
THAT WAS IT!
PROBLEM SORTED!!!
I CAN'T THANK YOU GUYS ENOUGH. In particular you RWOBS777 for taking me through this one step at a time.
I have a big grin taking over my face right now. :-)
Old Oct 13, 2018 | 01:34 PM
  #46
roppa440's Avatar
roppa440
Oh and I will try to get to the block end of the ground strap sometime over the winter to make sure that is as good as possible too. ;-)
Old Oct 13, 2018 | 02:04 PM
  #47
C5 Diag's Avatar
C5 Diag
Glad you got it sorted !!….actually I don't think I've cleaned that end of G105 myself...I highly recommend using this stuff on all your grounds once you get them cleaned...fantastic product....now go grab yourself a pint ...cheers !!
Old Oct 13, 2018 | 02:14 PM
  #48
C5 Diag's Avatar
C5 Diag
ALWAYS measure resistance on the 200 ohm scale...you will not get an accurate reading on the 200K setting !!
