Window support bar
Old Oct 14, 2018 | 02:02 PM
Z06Berlin's Avatar
Z06Berlin
Default Window support bar
Thought I had posted this already but can't find.
The leather on both support windows support beam is splitting. What is the proper name for this item or is it better to just have the leather replaced. Thanks for your help. Jim
Old Oct 14, 2018 | 02:06 PM
Z06Berlin's Avatar
Z06Berlin
Default post
Why can't I get my picture posted??
Old Oct 14, 2018 | 04:54 PM
redzg's Avatar
redzg
Did you insert through the advanced reply, and make sure it was an accepted file type?
Old Oct 14, 2018 | 05:47 PM
Z06Berlin's Avatar
Z06Berlin
Default reply
Yes, it is a JPG file, I just reduced the picture size to 7 inches and it seems to work, the wiggle line is my attempt to point out what I am writing about.
Old Oct 14, 2018 | 09:44 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I believe that's your a-pillar cover. You can pull it straight away to remove it. It has a couple of spring clips that just pop right out if you pull pretty much straight towards the driver's seat back. Maybe a little more inward towards the center of the car than that.
Old Oct 14, 2018 | 11:01 PM
jrprich's Avatar
jrprich
BTW,
The A-Pillar is covered with vinyl, not leather. You can likely find a nice used on eBay or contact Vettenuts for a replacement
To Window support bar
