Actual EBCM Amp Draw?
Old Oct 15, 2018 | 06:47 AM
GO_BLUE_VETTES's Avatar
GO_BLUE_VETTES
Default Actual EBCM Amp Draw?
I am redoing the power distribution system in my car. 2001 Z06
The main power circuit to the EBCM is protected by a 40A Maxi Fuse.
Anybody know what the actual amps are for an EBCM? Would it be possible to power and protect it with a 30A circuit?
Old Oct 15, 2018 | 07:16 AM
Kevova's Avatar
Kevova
The abs doesn't draw much until active. Pump will draw alot of current if it in and out of TC & ABS tracking , skid pad, sliding around on ice
is there a reason you want to reduce circuit protection?
Old Oct 15, 2018 | 10:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GM Engineers wouldn't have put it on a 40 Amp fuse if they didn't think it was necessary.
Old Oct 15, 2018 | 12:44 PM
GO_BLUE_VETTES
I have a CarTek PDM unit. Having a 30A protected circuit is easy- 40A is not. In order to do 40A I would use a separate external relay, but I am trying to avoid that. This particular circuit is the largest individual load on my car. I've held the pump and the EBCM in my hand before - it just didn't seem like a close to 40A load (maybe 32-33A if GM left 20% margin). Not sure if it is a wire size or voltage drop limit.
Old Oct 15, 2018 | 02:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Put an AMP CLAMP on the feed wire and give the EBTCM hell.. That should tell you the spike current and actual current draw under demanding conditions..
Old Oct 16, 2018 | 06:00 AM
GO_BLUE_VETTES
Thanks! That’s the next best solution - was just trying for some data.
To Actual EBCM Amp Draw?
