2001 corvette
Old Oct 20, 2018 | 02:46 PM
Teri Sheehy's Avatar
Teri Sheehy
1st Gear
Default 2001 corvette
I had my car inspected and now the engine light is on that never was before, they did get the exhaust tube they use get stuck in my exhaust and then lost coolant. Replaced coolant however light is still on. Help
Old Oct 20, 2018 | 03:02 PM
mmartinez's Avatar
mmartinez
For problems like this the best thing to do is post the codes on the DTC, do a search on this site and you will find out how to retrieve diagnostic trouble codes.
Old Oct 21, 2018 | 11:31 AM
mmartinez's Avatar
mmartinez
I was to quick to suggest pulling codes and posting them to find the cause of your CEL "CHECK ENGINE LIGHT", you can disconnect the positive battery cable for say half hour and reconnect to see if that will clear your CEL. A one time fault condition will trigger the CEL and it will take many run/stop cycles to clear, if the CEL is still on after power reset, you can take your car to most local auto parts stores and they can tell you what is causing your CEL, or you can retrieve the codes yourself and post them here on the forum.
Old Oct 21, 2018 | 11:54 AM
01pewtervert's Avatar
01pewtervert
Always disconnect the negative terminal first, otherwise you can risk creating a short circuit if while disconnecting the positive terminal your wrench touches a grounded part. A short circuit can cause damage and/or personal injury.
To 2001 corvette
