fuel gauges
Old Oct 22, 2018 | 10:44 AM
Doozie1's Avatar
Doozie1
Cruising
Default fuel gauges
New to owning a 1998 c5 convertible. Gas gauge drops to empty , already replaced the right hand fuel tank sender assembly. Still having same problem, what should i check next?
Old Oct 22, 2018 | 11:48 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Run Techron through...may take several tanks. I would try this before any further repairs.
Old Oct 22, 2018 | 12:07 PM
jcgunn's Avatar
jcgunn
Pull the DTC codes and look for:
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P1431 Fuel Level Sensor 2 Performance
DTC P1432 Fuel Level Sensor 2 Circuit Low Voltage
DTC P1433 Fuel Level Sensor 2 Circuit High Voltage
Old Oct 22, 2018 | 04:18 PM
Doozie1's Avatar
Doozie1
Cruising
P1431 was the code the first time and friends told me to change the right tank assembly, which I did an then drove the carr again an it reset the same code
Old Oct 22, 2018 | 04:25 PM
grantv's Avatar
grantv
When does it do this? Random? After you fill the tank?
Old Oct 22, 2018 | 04:42 PM
Doozie1's Avatar
Doozie1
Cruising
Seem to be every time I try to drive about a hour, 40 to fifty miles
To fuel gauges
