So I’m trying to reach my goal of 400rwhp. Kinda close but yet kinda far at the same time so far my mods are
the car is an AUTO
SLP lid
1 3/4 long tubes
DMH cutout
LS6 intake
mild cam 218/227 .600/.600 lift
PRC stage 2.5 862 heads
36lb injectors
all supporting mods lifters, pushrods, ect.
the car put down 380hp/371tq i don’t thinj these are bad numbers for the build the car does have 125k miles so that has a lot to do with it. Just trying to get to the 400rwhp mark. Please don’t say to swap a different cam or different heads I know a bigger cam would do better but then I’d have to replace the stall in the Trans and everything. Any suggestions on what I could add to get me there any suggestions would be great. I was thinking maybe a under drive pulley? Ported FAST 92/92?
How about a cam upgrade? DOH!
I don't know that much about your cam and heads, but kinda surprised you're not at 400, I guess the auto is sucking that final 20 out.
Seriously doubt an underdrive pulley will do anything near that gain. Maybe the 92?
the car is an AUTO
SLP lid
1 3/4 long tubes
DMH cutout
LS6 intake
36lb injectors
when My 6spd had stg 2.5 317 heads, cam (226/228 .600/.600) with 1 3/4” headers, LS6 intake I dynod 405/370. A year later I added ported FAST 90/90 & catless 1 7/8” headers and I dynod 433/396..... a gain of 27 hp and 26 tq.
I think a ported FAST will get you close to 400 and if you get rid of cats also you should for sure get there. My headers were cracking so needed replacement anyways, not a cheap upgrade but going catless is cheap! Obviously this isn’t an option for everyone.....
it does just a mild cam they call it a “High lift hot cam” because it has a .600/.600 lift. Even the tuner said it should be at 400 I guess I should of also stated that I made the 380hp on the 6th pull and it was a 101 degrees in the building of the dyno. I know someone that put down 632hp at one dyno then went to the same dyno as me and only put down 600hp. So I wanna say maybe the dunk reads low and I probably didn’t pick the best day to get a tune lol
I don’t have cats on it. Thinking about doing the fast 92/92 then just calling it a day probably buy one ported and I think that should easily get me at 400 since I made 380 on the 6th pull in a 101 degree building
Just in case your interested I’ll be selling my ported Fast 90/90 & adapter this winter because I’m putting the LS6 intake back on and supercharging it
that will get him to the 400 mark, 400 more if he wanted to
Go for the Fast 90 with an LS2 throttle body. It will get you very close. Add a decent CAI, like the Callaway Honker and you should go well over 400 rwhp.
Reason: Fix spelling.
I made 440 rwhp on my new LS1 motor and it has an LS6 intake, heads and throttle body. The cam and lifters (and a new short block) took me from 380 to 440. Car has Vararam, long tube headers, mid-pipe and Z06 mufflers. And a 6 speed.
