Strange C5 problem
Old Nov 1, 2018 | 09:57 AM
Deliso1's Avatar
Deliso1
Default Strange C5 problem
i have a 99
This is a problem nobody can seem to figure out, my Telescoping steering wheel only moves in and out from the seat switch and the switch on the colum doesn't do anything at all., push down brings it out and push up and it goes in. Also the seat only goes forward and back by pushing switch on an angle. I have not pulled out the driver seat yet but I did notice a couple orange wires hanging down underneath.
I bought the car like this and the previous owner didn't know why it was like that either.
Has anyone had this problem or heard if it??
Old Nov 1, 2018 | 10:06 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
This has been posted before by Zilla:
Telescoping Steering Column Calibration
Telescoping Soft Stops
After replacement of the seat control module, it is necessary to program the telescoping soft stops. Each soft stop is a programmable end of travel that is set approximately 1.3 cm (0.5 inch) from the mechanical end of travel. The steering column has a soft stop set at each end of the telescoping in/out movement. The system uses soft stops to prevent wear on the system by ensuring that the steering column movement stops before it reaches its mechanical end of travel in any direction. The soft stops are initially programmed at the factory. The stop positions may be reprogrammed, which is necessary any time the seat control module is replaced, as described in the following procedure.
Telescoping Soft Stop Programming Procedure
1] Turn ignition to ON, leaving the engine off.
2] To set the telescoping in soft stop, press the telescoping COLUMN IN switch at least eight times or until the column moves.
3] Press the telescoping COLUMN IN switch and hold the switch until the column travels all the way in, and continue to hold the switch about a second after motion stops at the mechanical end of travel. The soft stop for the column in position is now set. The seat control module automatically goes back to the normal mode of operation.
4] Repeat steps 2 and 3, using the COLUMN OUT switch, to set the column out position soft stop
Old Nov 1, 2018 | 10:29 AM
Deliso1's Avatar
Deliso1
Default Tried that
I did try that and it did not correct it
Old Nov 1, 2018 | 11:52 AM
Moved to C5 Tech.
Old Nov 1, 2018 | 12:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Let us know if it works..
Bill
To Strange C5 problem
