Harmonic Balancer Replacement
Old Dec 15, 2018 | 08:05 PM
MilsteadGC's Avatar
MilsteadGC
My first GM car and I'm still in a state of shock that GM would produce such a OEM POS.....for so many years!!!
Good to hear about the Dayco. Gonna think this over.
Thanks, George
Old Dec 16, 2018 | 11:05 AM
Josephu's Avatar
Josephu
I put the Powerbond/Dayco PB1117SS Race balancer on mine. It has a thick snap ring holding the outer sleeve to the center hub. This way even if the rubber goes bad, the ring cannot come off into the timing cover or the steering rack. Well worth the money in my opinion. $250 dollors at Summit or Jegs.
Old Dec 16, 2018 | 11:22 AM
Gunnmetalblue's Avatar
Gunnmetalblue
The damper is just one example of poor GM engineering on these cars. Look at the 'Known Issues' sticky.
Old Dec 16, 2018 | 12:17 PM
MilsteadGC's Avatar
MilsteadGC
You are the second member to recommend Powerbond. Just took a look at the PB1117SS. Very impressive and only slightly more expensive than the Summit race damper. I am going to take your advice on this one. Hope this replacement turns out to be a one time thing.
Thanks for your help.
Old Dec 16, 2018 | 12:22 PM
MilsteadGC's Avatar
MilsteadGC
Taking your advice. Going with the Dayco/Powerbond PB1117SS.
Old Dec 18, 2018 | 03:47 PM
Josephu's Avatar
Josephu
Your Welcome. I got mine on with no problems. Dont forget to change the front seal also.
