Heater question
Old Nov 7, 2018 | 10:38 PM
1978vett's Avatar
1978vett
Default Heater question
is the ac supposed to be on when trying to heat my car. 2004 Vette. The ac light is on. I must be doing something wrong when I turn it on.
Old Nov 7, 2018 | 11:06 PM
grantv's Avatar
grantv
Is it on the windshield? If so, that's normal.
Old Nov 7, 2018 | 11:08 PM
Moved to C5 Tech.
Old Nov 8, 2018 | 01:30 AM
TastyBacon's Avatar
TastyBacon
If you have auto climate control, it will often start in defrost mode, or split between defrost and heat. It's normal, the system is just programmed to run the defrost to try to keep the windows from fogging up.
Old Nov 8, 2018 | 06:52 AM
1978vett's Avatar
1978vett
Thanks for the replies.. sounds like it’s working as it should.
Old Nov 8, 2018 | 10:38 AM
Belba184's Avatar
Belba184
i had the same question. Anytime I turn my defroster on the a/c light turns on and I couldn't get it to shut off. Thanks for asking
Old Nov 8, 2018 | 11:12 AM
1978vett's Avatar
1978vett
I think the ac comes on anytime the defrost is used , I was curious because my ac comes on when I’m trying to use my heater , I couldn’t find much in the owners manual..
Old Nov 15, 2018 | 02:40 AM
ncali's Avatar
ncali
The ac acts as a dehumidifier. so when you have a cold morning with condensation on the glass the ac and the defroster together dry the air
To Heater question
