Will 245 40 19 & 305 30. R19 work?
Old 11-12-2018, 06:50 PM
cobrachuck
cobrachuck's Avatar
Default Will 245 40 19 & 305 30. R19 work?
Hello, looking at a 2004 with these size tires on it, of course ABS & traction control lights are on.
The car looks great this way. Can it be corrected? What can be done to correct?
Old 11-12-2018, 07:35 PM
cobrachuck
cobrachuck's Avatar
Sorry I ment to say 18" front 19" rear
Old 11-12-2018, 07:53 PM
BigGun
BigGun's Avatar
The tire size is not likely to be the problem. You need to use the dic and pull the codes to get an idea of what is really causing the problem. You should do this on any C5 you are considering purchasing.
cobrachuck (11-13-2018)
Old 11-13-2018, 09:20 AM
93Polo
93Polo's Avatar
CI 3-4-5-9 Veteran
Old 11-13-2018, 09:43 AM
Gordy M
Gordy M's Avatar
IF the TC/AH are lit it is not because of the tires, you have 1/2" offset front to back and that should not cause the lights to go on. When you pull the DTC codes, make sure the engine is running and you drove it around the block, look at the C codes and make sure there are no C1214 or C1287-1288 codes as those are major issues to fix. There are many more DTC that can cause problems but those are the ones I would look for.
Old 11-13-2018, 12:36 PM
cobrachuck
cobrachuck's Avatar
That's what I was thinking I will drive the car next Friday pull all codes & keep you posted, still on vacation
To Will 245 40 19 & 305 30. R19 work?
Quick Reply: Will 245 40 19 & 305 30. R19 work?
