What do you think this is?
Old Nov 20, 2018 | 09:41 AM
am3gross's Avatar
am3gross
rwobs777 thanks for the pictures! that will make it much easier.
one question and like i said probably will be a dumb one but there is no reprograming of the key needed right? should not but just making sure here.,
thanks
Mike
Old Nov 20, 2018 | 10:08 AM
wcsinx's Avatar
wcsinx
thanks
Mike
Correct, you're only swapping the switch itself. Everything else remains the same ... no reprogramming / re-keying needed.
Old Nov 20, 2018 | 10:33 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
thanks
Mike
Mike, NO key programming....you'll be using the same one !!
Old Nov 20, 2018 | 10:57 AM
am3gross's Avatar
am3gross
alright fellas, you guys have given me the tools needed for this adventure, i get off at 1600 EST and should be installing the part shortly after. i will keep everyone posted once the job is complete. gunna be an excitng adventure!
thanks again for all the help!
Mike
Old Nov 20, 2018 | 05:57 PM
am3gross's Avatar
am3gross
Rwobs777! You are my hero!that ignition switch fixed the issue! Great job! Took it all apart, put the new one in and bam! She starts and runs..
I am pretty confident it will fix the issue, when I started the evolution the lights in the dash were pretty dim, after the install, nice and bright! Along with the stroke of the key, she fired up. I cant thank you and everyone else on this great forum for the great advice.
thank you all!
Mike!
Old Nov 20, 2018 | 06:21 PM
am3gross's Avatar
am3gross
Also as a side note, I cleared all the codes, I will see what codes happen over the next week or so if any. Then report.
Old Nov 20, 2018 | 07:59 PM
C5 Diag's Avatar
C5 Diag
Super !!!...glad you got it running !!
