Help with part numbers: Hoses and seals
Old Nov 19, 2018 | 09:38 AM
turabo87's Avatar
turabo87
Default Help with part numbers: Hoses and seals
Hi folks,
I need help to know the part numbers and where to buy the following:
1. Passenger side valve cover rubber vent tube (that connects from top of valve cover and goes to throttle body)
2. Rubber lip seal for the windshield wiper cowl/shroud (it's a thin lip seal that spans the entire windshield wiper cowl/shroud, and it's right on top of the wiper cowl).
Thank you.
Old Nov 19, 2018 | 12:10 PM
TastyBacon's Avatar
TastyBacon
Not sure about #1--is yours cracked/broken? I have one that's used but still in good shape, I would be happy to send it to you since I don't need it anymore.
#2 is not available separately. I am using a piece of generic edge trim from O'Reilly: https://www.oreillyauto.com/detail/b...s37203/2519099. It's not perfect, but it's better than nothing.
Old Nov 19, 2018 | 12:51 PM
turabo87's Avatar
turabo87
Sure, I’d take yours. #1 Hose is toasted. Yesterday I replaced my valve cover gaskets and grommets, and doing so during the reinstallation I accidentally cracked part of the end of the hose. If i couldn't find it, I was going to get a piece of automotive hose from car parts store and call it a day, but I’d rather have the actual hose that has all the right bends.
To Help with part numbers: Hoses and seals
