What FAST setup
Old Dec 2, 2018 | 03:31 PM
Midnight_Z's Avatar
Midnight_Z
Default What FAST setup
Hey guys. I have a 2003 z06. Car currently has 1 7/8 headers catted x pipe and corsa sports. Halltech intake and a tune. Car will be going in for Texas speeds stage 2.5 ported/milled heads and a cam this month. Now I am contemplating going all out and adding a fast setup. What exact intake manifold do I want with this setup, and what throttle body would I need to run? Also, what else is needed for this upgrade? New fuel rails, injectors? I’m trying to get an idea on price for the parts and if it is worth it all while it’s torn apart. After this I do not plan on doing any other engine modifications. Thanks.
Old Dec 2, 2018 | 03:58 PM
493lszosix's Avatar
493lszosix
Fast 102, ls2 throttle body, harness adapter for throttle body, new fuel rails, ls2 fuel rails will work, probably need new injectors but don’t install injectors till doing the tune, you don’t want to run the motor with different injectors and incorrect flow data
Old Dec 2, 2018 | 04:26 PM
Midnight_Z's Avatar
Midnight_Z
so I’m looking at 1500 bucks about? Is it worth it? I figure I will prob need new injectors as well, but we’ll see when it’s tuned.
Old Dec 2, 2018 | 05:45 PM
feeder82's Avatar
feeder82
And keep in mind, on some cars the 102 fast intake hits the firewall and you need lower engine mounts or butcher the firewall.
Old Dec 2, 2018 | 05:49 PM
1999corvettels1's Avatar
1999corvettels1
Does the FAST 102 fit the C5 without lowering the cradle?
Seems the FAST 92 fits, but I have no personal experience, just what I've read and could be wrong.
What are your goals and plans for this car?
Old Dec 2, 2018 | 06:51 PM
Midnight_Z's Avatar
Midnight_Z
I was just doing some more research and it seems like the fast 92 would be a good option. It’s my fun car. Might see the track. I just want to get the most out of it na. What’s needed to run a fast 92 setup? Is it worth it?
Old Dec 2, 2018 | 06:54 PM
493lszosix's Avatar
493lszosix
It’s probably worth about 30hp or so, if you’re going to turn 7000+ rpms then it’s worth it but if you’re staying around 6500 or so then I wouldn’t bother
as far as hitting firewall every car is different, some hit some don’t, also if you have milled heads/ thinner gaskets ect that will give slightly more clearance
Old Dec 2, 2018 | 11:00 PM
Stroker87's Avatar
Stroker87
i had a fast 92mm on my 01 zo6 stock fuel rails bolt right on, you will need a ls2 throttle body silver blade (not the gold) and adapter harness, even if you keep your stock intake any thing over 410ish to the wheels your pushing the limits of the 28lb injectors
is it worth it? it was for me i could not see doing h/c full bolt'ons and leave HP on the table by keeping the stock intake
parts list
fast 92mm cathedral port manifold
gm ls2 silver blade throttle body (OR) after market
ls1 to ls2 throttle body harness
Old Dec 3, 2018 | 10:44 AM
Midnight_Z's Avatar
Midnight_Z
parts list
thank you sir. Just what I was looking for.
Old Dec 3, 2018 | 11:27 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
YES I had to do some "butcher work" on my FAST intake as the MAP sensor hit the firewall
Old Dec 3, 2018 | 11:47 AM
Stroker87's Avatar
Stroker87
no problem! have any other question happy to help
Old Dec 3, 2018 | 12:41 PM
Midnight_Z's Avatar
Midnight_Z
other than a gasket kit from fast, what else is needed? Do I need different fuel rails?
Old Dec 3, 2018 | 02:44 PM
96darkhorse's Avatar
96darkhorse
Fast intake ( if used, get new fast intake gaskets)
Your stock fuel rail will work if going with Fast 92. They wont work with Fast 102.
Bigger injectors
ls2 Tb like already mentioned
Ls1 to ls2 Tb harness like stated
Old Dec 3, 2018 | 06:35 PM
Stroker87's Avatar
Stroker87
any cathedral port gaskets will work dont have to be fast, only other thing comes to mind is valley cover bolts need to swap to hex button head bolts but if your getting a new intake should come with all the hardware, if picking up a used one most of the time they dont come with them
swap is pretty straight forward, your stock rails work no mods needed
Old Dec 4, 2018 | 03:20 PM
ASRoff's Avatar
ASRoff
for an "ALL out N/A" build the option I would go with would be the MSD intake........ and I think the stock rail's could be used if I remember correctly.... then you could spring for a nick Williams 102mm....
Old Dec 4, 2018 | 03:32 PM
Midnight_Z's Avatar
Midnight_Z
I think I’m going to pull the trigger on the fast 92 with a ls2 tb. Might as well go all in at this point. Hopefully this set up is worth the extra cost from stock.
To What FAST setup
