Whining coming from Alternator?
Old Dec 20, 2018 | 12:10 PM
brivette91's Avatar
brivette91
Default Whining coming from Alternator?
Hi,
Purchased a C5 a few months back, now i have a high pitched whine coming from i believe the alternator, when signal light or brake light is activated the whining then pulsates with the blinker. Also when headlights are engaged it take a few secs before the gauge cluster lights up(very slowly). any thoughts? The battery at the terminals is reading 13.1 volts, it is a cheap battery(O'Reilly special) though i'm wondering could that be it as well? battery dated 3/18 so its newer.(but that doesn't mean anything in AZ)
Thanks for your help.
Old Dec 20, 2018 | 01:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you can give me a call. Its easier than writing a BOOK about what you need to check.. :-)
PM Sent with Cell#
Old Dec 20, 2018 | 02:46 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Sounds like a bad alternator diode from what you’re telling us !!
Old Dec 20, 2018 | 05:43 PM
3sACROWD's Avatar
3sACROWD
When you are hearing the whine, are you sitting in the car or are you standing outside? If sitting inside, you need to exit the car and determine the location of the sound. The whining sound could be the alternator but it could also be the fuel pump. The fuel pump is located behind the driver's seat so you need to confirm location of the sound. A whining fuel pump is actually pretty common and can become louder after long periods of driving.
The fluctuation in the whining when the turn signals are on is simply the current draw on the system. Not sure what the cause of the dash lights being slow to light can be. Maybe the light sensor on the dash isn't working well or the dash lights are adjusted low.
Old Dec 20, 2018 | 05:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
He has a 97 A4.. All A4s have a DE-COUPLER pulley on the alternator. They can and do go bad and can cause weird noise. So, he is going to check that and then do an Output test on the alternator to see if it has any AC on the output.
Old Dec 20, 2018 | 06:04 PM
grantv's Avatar
grantv
I think a PO dropped in a blower, and moved the alternator elsewhere. If my hunch is right, a whining sound is somewhat standard!
Old Dec 21, 2018 | 07:27 AM
3sACROWD's Avatar
3sACROWD
Thanks for the update Bill. I must have had an old browser open because there were no replies when I read the post yet my post was hours later than the previous person's post. I wouldn't have replied knowing he was in capable hands. It will be interesting to find out the final diagnosis.
Old Dec 21, 2018 | 03:28 PM
Ed Ramberger's Avatar
Ed Ramberger
If it needs a decoupler - here is a post I did when I replaced mine.
https://www.corvetteforum.com/forums...placement.html
Old Dec 29, 2018 | 12:02 AM
brivette91's Avatar
brivette91
Default whining alternator
found the problem, the starter solenoid is defective. i found a place in town here in the Phoenix area,(Copper State Alternator and Starter) they confirmed my starter solenoid was defective, they had a replacement for me. Also they carry rebuilt alternators in stock, the correct Valeo for our cars. Thanks for everyone's help!(at least the knowledgeable ones!)
To Whining coming from Alternator?
