Hvac problem
Old Jan 1, 2019 | 01:10 PM
Jerry Maxwell's Avatar
Jerry Maxwell
5th Gear
Default Hvac problem
I have a 97 C5 my battery went dead I replaced battery. Now drivers side only blows cold while passenger side blows only hot. It still switches to different modes on both sides defrost,floor,ac, etc. It shows 5 codes on dic B0361H,B0363H,B0367H,B0441HC, &B0446HC. Anyone got any suggestions for a fix? Everything was working fine till battery died.
Thanks,
Madmax
Old Jan 1, 2019 | 01:47 PM
STRMLNE's Avatar
STRMLNE
Did you clear all of the codes and see if it works after?
Old Jan 1, 2019 | 01:51 PM
Jerry Maxwell
5th Gear
Yes cleared codes but they come back.
Old Jan 1, 2019 | 03:18 PM
GCG's Avatar
GCG
Originally Posted by Jerry Maxwell
...my battery went dead I replaced battery. Now drivers side only blows cold while passenger side blows only hot... ...It shows 5 codes on dic B0361H, B0363H, B0367H, B0441HC, & B0446HC... ...Everything was working fine till battery died...
Have you tried recalibrating the A/C Actuators?
Shown as Current:
  • B0441 Left Actuator Out of Range
  • B0446 Right Actuator Out of Range
Shown as History:
  • B0361 Left Actuator Feedback Short to GND
  • B0363 Left Actuator Feedback Open
  • B0367 Right Actuator Feedback Open
Old Jan 1, 2019 | 04:27 PM
Jerry Maxwell
5th Gear
Yes tried recalibrating still no change
Old Jan 1, 2019 | 04:31 PM
wadenelson's Avatar
wadenelson
Any chance vehicle was jump-started backward prior to battery replacement? Sorry, gotta ask.
Old Jan 1, 2019 | 04:34 PM
Jerry Maxwell
5th Gear
No it was in garage in storage. Hadn’t been driven in 2 weeks.
Old Jan 1, 2019 | 09:33 PM
redzg's Avatar
redzg
Tried disconnecting and reconnecting the battery yet? Recalled seeing an interesting article on the Super Chevy web page:
http://www.superchevy.com/how-to/add...orage-voltage/
Old Jan 1, 2019 | 10:32 PM
Moved to C5 Tech.
Old Jan 1, 2019 | 10:43 PM
Jerry Maxwell
5th Gear
Yes I tried disconnecting battery left it disconnected for 5 or 6 minutes. Still no change. It clears an works for a minute or 2 then goes back to cold on drivers side and hot on passenger.
Old Jan 2, 2019 | 12:01 PM
Josephu's Avatar
Josephu
Put in a can of freon.
To Hvac problem
