Help with “new” gm starter issue
Old Jan 12, 2019 | 11:58 AM
STRMLNE's Avatar
STRMLNE
Default Help with “new” gm starter issue
I recently had a gm starter put in at the dealership. (Apparently all c5 gm starters are now remanufactured). Car starts fine now. However, there is a small “spinning”, kind of a slight “zinging” noise just after start up that lasts only for a second and goes away. It’s NOT any type of grinding noise.
The dealership agreed that it sounded weird but that everything was working properly. They ultimately warrantied and replaces the starter TWICE. All three in total have the exact same noise.
Has as anyone ever come across this issue? Or does anyone have a recommendation for me of what to do? Dealer actually said they would warranty it one more time. I guess I could try another brand starter but AC Delco seems to be the best aside from this issue. Thanks.
Old Jan 12, 2019 | 12:26 PM
bighank's Avatar
bighank
Default I had a dead spot and replaced starter years ago - no noise
My starter would not engage and I could start the car by going under the car and whacking the starter hard with a tire iron. I got a remanufactured GM starter from the distributor who sold GM and Delco parts to GM dealers. No noise. I suspect something like the bearings in the starters are bad. Eons ago when I worked on IBM equipment we got a bad batch of motors and had to go back and replace all of them that we installed a month or two after first replacing them. The warranty you now have will be forgotten or expired when the starter bites the dust.
If you paid a fortune for the dealer to install the starter at list price then you should get one that works and sounds like the original one on your car.
Old Jan 12, 2019 | 12:38 PM
mmartinez's Avatar
mmartinez
That zinging sound is actually the starter drive, sometimes referred to as the Bendix. That zinging sound is not normal, I replaced my starter about three years ago because of problems with the solenoid, and bought a Bosh starter with the two long mounting bolts and haven't had problems since.
Old Jan 12, 2019 | 01:09 PM
STRMLNE's Avatar
STRMLNE
The dealer explained that it’s somethinf that is still touching the flywheel after the car starts. But it’s just very unusual that the same noise is there with three different new gm starters. Is Bosch a good brand? At this point I think I’ll have try an aftermarket starter. That zinging noise is annoying. And like you said, you pay dealer prices, you want things to work like stock.
Old Jan 12, 2019 | 01:24 PM
Smoken1's Avatar
Smoken1
I also used the Bosch starter with the 2 long bolts and don't have that noise
Old Jan 12, 2019 | 02:01 PM
STRMLNE's Avatar
STRMLNE
Thanks. What is the benefit of the one longer bolt? Vibration?
Old Jan 12, 2019 | 02:16 PM
Smoken1's Avatar
Smoken1
Read thru this thread posted by dadaroo
https://www.corvetteforum.com/forums...the-block.html
Old Jan 12, 2019 | 02:37 PM
STRMLNE's Avatar
STRMLNE
Thanks. Was there a gm tsb on this?
Old Jan 12, 2019 | 02:52 PM
Smoken1's Avatar
Smoken1
Not that I have seen
Old Jan 12, 2019 | 03:03 PM
STRMLNE's Avatar
STRMLNE
Ok. Thanks. Still trying to figure out how to fix this noise issue. Looks like some people had the issue with the Bosch starter too.
Old Jan 12, 2019 | 04:58 PM
Russ K's Avatar
Russ K
You will need to install a starter shim between the starter & engine, as there is not enough clearance between the starter drive gear & the flywheel.
Russ Kemp
Old Jan 12, 2019 | 05:09 PM
STRMLNE's Avatar
STRMLNE
Thanks. Any idea why here would be no noise with original starter but the zinging noise starts with the replacement? Thanks.
Old Jan 12, 2019 | 05:24 PM
Russ K's Avatar
Russ K
Slight dimensional differences from the mounting pad to the starter armature. Some replacement starters come with several thickness starter shims in the box.
Russ Kemp
Old Jan 12, 2019 | 05:34 PM
STRMLNE's Avatar
STRMLNE
Ok. Thanks. I’ll ask the dealer if they have shims.
Old Jan 12, 2019 | 07:48 PM
STRMLNE's Avatar
STRMLNE
You would think that a gm replacement part would fit perfectly and not required any modifications.
Old Jan 13, 2019 | 02:16 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
"I recently had a gm starter put in at the dealership. (Apparently all c5 gm starters are now remanufactured). "
I see new acdelco at rockauto.???
Old Jan 13, 2019 | 03:35 PM
STRMLNE's Avatar
STRMLNE
Please post the link. I looked at rockauto. The one I saw was reman.
To Help with “new” gm starter issue
Old Jan 14, 2019 | 10:18 AM
punz's Avatar
punz
I searched a 1999 Corvette and came up with this:
https://www.rockauto.com/en/catalog/...ter+motor,4152
Old Jan 14, 2019 | 02:24 PM
Russ K's Avatar
Russ K
You need these shims; https://www.rockauto.com/en/moreinfo...3123&jsn=10514
Russ Kemp
Old Jan 14, 2019 | 10:01 PM
STRMLNE's Avatar
STRMLNE
Thanks. I was looking if they sell shims. Hopefully this will fix the problem. Something still is hitting the flywheel after it starts.
