Help with “new” gm starter issue
Old Jan 22, 2019 | 12:05 PM
STRMLNE's Avatar
STRMLNE
Thought I would give an update here. The dealer put in a fourth replacement starter (reman from gm). The issue is now fixed. Shims weren’t needed. Thanks for all the suggestions.
Old Jan 22, 2019 | 04:37 PM
mmartinez's Avatar
mmartinez
Thanks for the update, something I forgot to mention is sometimes it's best to send your starter to somebody who will rebuild it for you, that way your assured that it will fit correctly. Hope your starter problems are behind you for a long time.
Old Jan 22, 2019 | 04:45 PM
wcsinx's Avatar
wcsinx
Originally Posted by mmartinez
That zinging sound is actually the starter drive, sometimes referred to as the Bendix. That zinging sound is not normal, I replaced my starter about three years ago because of problems with the solenoid, and bought a Bosh starter with the two long mounting bolts and haven't had problems since.
This
The zinging noise typically points to an incomplete disengagement by the bendix drive of your starter motor. It's not an uncommon problem at all (shimming starters is most certainly a thing). So I'm a little surprised that your shop doesn't know this.
Old Jan 23, 2019 | 03:12 PM
STRMLNE's Avatar
STRMLNE
Not sure either. But it’s twken care of now thankfully.
Old Jan 25, 2019 | 01:12 AM
ncali's Avatar
ncali
the starter drive is hanging up in the flywheel . Shim the starter like the old chevys or you will burn that one also
