Horn blows
Old Jan 21, 2019 | 05:08 PM
digmyvette's Avatar
digmyvette
Default Horn blows
Soooo, I'm working on a no rear tail light on a 1999 F150 and I hear a car horn go off. It blared for about a minute and I wondered why no one came to turn it off. Soooo, I wandered over to find it was my vette making the ruccus! So I pulled the fuse. Thought it might be from the rain last night but it was dry all day yesterday and today and when I plug in the fuse, the horn goes off again!! Any body have a clue??
Old Jan 21, 2019 | 05:43 PM
Velocity_Vette's Avatar
Velocity_Vette
It's very common. The horn membrane in the wheel is having issues. If you Google it you'll see a lot of individuals with the same symptoms including step-by-step servicing.
Old Jan 21, 2019 | 06:26 PM
Robrote's Avatar
Robrote
I have a no horn condition at the wheel. The horn does work with the alarm etc. I think I'm heading down the membrane lane shortly.
Old Jan 21, 2019 | 09:46 PM
svo's Avatar
svo
Mine ended up being the Turn signal switch.
Be sure to test the membrane switch with a voltmeter before replacing it. I replaced mine and it ended up not being the problem.
Old Jan 22, 2019 | 10:41 AM
Robrote's Avatar
Robrote
Thanks for the heads up. I need to get a wiring diagram and do some testing,
Old Jan 22, 2019 | 02:21 PM
svo's Avatar
svo
Search my posts,....one of my first posts was about my horn a while back. And finally the solution for mine after chasing it for a while.
To Horn blows
