Clutch and supporting mod time
mcleod RXT w/balanced billet flywheel. ARP bolts
tick master cylinder
new slave/throwout
tick remote speedbleeder
driveshaft shop carbon fiber driveshaft (eliminates the rubber couplers in torque tube)
new torque tube bearings
hinson motor and transmission mounts
Side note: I assume you also will be changing the pilot bearing while you’re doing the clutch? Also, do some forum searching on match balancing your new clutch assembly with the OEM unit. There are lots of opinions on this and plenty of well documented facts. Collect that facts and make the decision for yourself. If you’re willing to take the risk with potential driveline vibrations, skip the step and roll the dice. I took the risk when I installed my Monster LT1-S clutch and got “lucky”. No vibrations.
Other things to consider:
- Fuel filter (extremely easy to do with the drivetrain out)
- Rear differential axle seals (if you have a leaky butt)
- Rear suspension components (ball joints, shocks, control arm bushings, tie rod ends, wheel bearings, etc...)
- Lower shift box
- Address any transmission leaks
- Interior trim (replace any cracked parts or change out shift boots, etc.)
- Exhaust upgrade
- Upgrade to a stiffer tunnel plate
I'd also recommend doing the simple measurements to determine whether your slave cylinder needs shimming. It's quick and easy insurance that everything will function correctly once all is back together.
