HVAC problems
Old Jan 26, 2019 | 11:25 AM
dburdick's Avatar
dburdick
Default HVAC problems
I have been trying to access JR-Vette's link on actuator reindexing but the link must be broken. From what I've read here, it sounds like the real fix is to replace the HVAC controller in my '99 c5 with a 2001 or later controller, to fix the problem of the actuator being told to try to close the door to far. If this is right, can anyone tell me the correct part number for the 2001 or later controller?
Old Jan 26, 2019 | 11:43 AM
dleibman's Avatar
dleibman
Having the same problem for the second time in a year. This time not as bad. Not blowing strong on drivers side and temp not as cold as passenger side. Does not happen all the time. Last time had controller and actuator replaced. No problem with passenger side at all
Old Jan 26, 2019 | 11:48 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I did this in my 99 C5, I just bought one from a forum member selling one from a 2001 Z06 with dual climate control, as long as its a 01 and up it has the board with the "logic" that fixes the issue. That being said I eventually pulled the dash and replaced both actuators a few years later. Its not as daunting as it seems.
oh yeah, don't overpay for a head unit, some people want waaaaaay to much for them
Old Jan 26, 2019 | 11:53 AM
pewter99's Avatar
pewter99
as for the re-indexing procedure if you are gonna pull them out just replace them
Old Jan 27, 2019 | 07:59 AM
dburdick's Avatar
dburdick
Thanks!~
Old Jan 27, 2019 | 03:42 PM
GUSTO14's Avatar
GUSTO14
Default Reindexing HVAC Actuators on the C5 Corvette
I copied down the procedures for reindexing the actuators a while back just to be sure I had a copy if I needed them...
Never know when you might need it.
Good luck... GUSTO
File Type: doc
Old Feb 3, 2019 | 03:21 AM
golfnutts's Avatar
golfnutts
Here you go: How to fix / repair HVAC climate actuators - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Feb 3, 2019 | 09:55 PM
pewter99's Avatar
pewter99
oh yeah, one more very important thing...make sure the new actuators work BEFORE you put that dash back together....you can plug the head unit in and turn the key to get everything running, run them through the various functions....didn't happen to me but my buddy had one of his techs do a new actuator install and put it back together to find out it didn't work,,,,he fixed it on his own time
Old Feb 3, 2019 | 10:36 PM
redzg's Avatar
redzg
oh yeah, one more very important thing...make sure the new actuators work BEFORE you put that dash back together.... my buddy had one of his techs do a new actuator install and put it back together to find out it didn't work,,,,
Now you tell us this story? Just when my new to me dash is back in place? ;-)
To HVAC problems
