directionals
Old Feb 5, 2019 | 01:50 PM
wopvette's Avatar
wopvette
8th Gear
Default directionals
My 2001 c5 has erratic turn signal problems
Old Feb 5, 2019 | 02:02 PM
FYRARMS's Avatar
FYRARMS
Okay. Is there more to this story?
Old Feb 5, 2019 | 04:08 PM
SilverC54me's Avatar
SilverC54me
What are the issues with the turn signals. Are they working some times, are they flashing fast? Are left and right signals having the same or similar issues?
Gary
Old Feb 5, 2019 | 04:29 PM
ShagVette's Avatar
ShagVette
Maybe there's a short in the bulb connector - have you tried to replace them?
Old Feb 5, 2019 | 05:01 PM
JR-01's Avatar
JR-01
If sometimes they work and sometimes they don't, it might be your emergency flasher. Try cycling it a few times for a temporary fix.
Old Feb 6, 2019 | 12:02 AM
Moved to C5 Tech. And it would help if you gave a better description of just what is going on with the car.
Old Feb 6, 2019 | 10:00 PM
redzg's Avatar
redzg
Well, I can't speak for the OP, but mine mostly flash fast, as though a lamp were burned out, but randomly flash at a normal rate. I've always figured it was a normal tail light kind of problem -- i.e. a bad ground, but haven't taken the time to clean them all yet.
Old Feb 6, 2019 | 10:20 PM
wopvette's Avatar
wopvette
8th Gear
If I turn the flashers on first sometimes the signals will work.
Old Feb 6, 2019 | 11:33 PM
ncali's Avatar
ncali
when you turn the turn signal on and it does not work , put it back in the center and turn on the hazard flashers. shut the hazards off and try the turn signal again. repeate that every time they dont work
To directionals
