Which Cam/Head package to get???
Old Feb 18, 2019 | 07:56 PM
mmo24's Avatar
mmo24
Default Which Cam/Head package to get???
https://www.texas-speed.com/c-3237-c...tte-2002.aspx#
Out of these which should I get? Right now my 02 C5 base is completely stock. I plan on getting intake, exhaust, x-pipe, long tubes, hi-flow cats. Wondering which cam package to get along with what cams and all that. Will be mostly driving on the street no racing or tracking.
Old Feb 18, 2019 | 09:09 PM
niterydr's Avatar
niterydr
I'd start with determining your goals and the intended use of the car. I have the PRC 225 as cast and a 228/232 cam on the way to me.
Old Feb 18, 2019 | 09:22 PM
mmo24's Avatar
mmo24
What're your goals with that setup? I guess my goal is giving my dads 2016 Challenger a good run for his money.
Hes got the 392 hemi in his.
Old Feb 18, 2019 | 09:51 PM
C5 Kirkland's Avatar
C5 Kirkland
So he has 500hp at the wheels. Go FI and blow his doors off.
Old Feb 18, 2019 | 10:18 PM
mmo24's Avatar
mmo24
Lol I wish! $$$ would be the issue there.
Old Feb 19, 2019 | 12:06 AM
knr13's Avatar
knr13
well do you have a M6 or Auto if your running a auto trans check and see what rear gear you have ? if you don't know look for your RPO codes in your glove box and post a pic .
you would be amazed what that car will do with a 3.42 rear gear and some nice bolt ons and a great tune i would look into doing these mods first which will help take to the next step CAM or HEADS or BOTH
BTW are you looking to do the yourself or a shop ?
Old Feb 19, 2019 | 12:21 AM
mmo24's Avatar
mmo24
I have an M6. Also I was going to have a shop do the install for head and cams. I can do the other minor mods myself like exhaust, intake, headers etc.
Which bolt ons?
Old Feb 19, 2019 | 02:46 AM
knr13's Avatar
knr13
Which bolt ons?
i would start with
exhaust,
intake,
headers
a good tune
driver mod
this will work very well and very much needed for cam and heads work at its best
keep in mind them 392 do make great power BUT there FAT 4500lbs i think VS your 3200lbs car
BTW whats your budget ???
Old Feb 19, 2019 | 03:09 AM
mmo24's Avatar
mmo24
i would start with
exhaust,
intake,
headers
a good tune
driver mod
Sounds good thank you!! And around $3-4000.
Old Feb 19, 2019 | 03:24 AM
knr13's Avatar
knr13
https://www.corvetteforum.com/forums...uick-list.html
Old Feb 19, 2019 | 11:58 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Goals?
Auto or M6? if auto torque converter?
Gears?
3-4K? Are you turning the wrenches? Does that including buy the cold air induction, headers?
Old Feb 19, 2019 | 12:12 PM
My Vette Life's Avatar
My Vette Life
Why not build an ls3 instead? Cost will be similar and im talking a diy.
Someone else doing it for you, then forget it cost almost close to half what the c5 is worth.
Old Feb 19, 2019 | 12:16 PM
Mr. Jones's Avatar
Mr. Jones
TSP .660" Dual Valvespring Kit Featuring PAC Springs w/ Titanium Retainers
  • Texas Speed Bald Eagle 227/234 LS1/LS2/LS6 Camshaft for NA Appllications
  • 113 LSA
  • 7.475"
  • Cloyes LS1/LS2 Single-Roller Hex-A-Just w/ Z06 Chain, 3-Bolt Cam (9-3158A)
  • Melling High Volume Oil Pump (#122-MEL10296)
  • Stainless Steel Intake/Exhaust Valves
  • 227 heads
  • .035 head gasket
  • pushrod upgrade
  • ARP bolts
  • FAST manifold
  • A tune (do all upgrades at once or pay for a tune again)
  • headers
  • 3.90 gears
  • A good clutch
or a A & A or ECS supercharger
Old Feb 19, 2019 | 03:33 PM
mmo24's Avatar
mmo24
Originally Posted by 93Polo
Goals?
Gears?
Goals 400RWP
M6
would have shop do heads/cam. I can do headers, exhaust, intake, etc.
Old Feb 19, 2019 | 03:34 PM
mmo24's Avatar
mmo24
As in buying a ls3 block and building? Sounds a lot more difficult.
Old Feb 19, 2019 | 03:55 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Goals 400RWP
M6
I agree with the 227 cam further if you have the time I'd do the cam swap yourself.
Old Feb 19, 2019 | 04:43 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Having replaced a LS6 with another LS6, it would be. On your budget, pick a cam and run with it.
To Which Cam/Head package to get???
Old Feb 19, 2019 | 11:16 PM
My Vette Life
Yes and no it wont. Plus you will make more than 400. Way more
Old Feb 20, 2019 | 01:07 AM
mmo24's Avatar
mmo24
Okay, I will look into it.
Old Feb 20, 2019 | 01:21 AM
My Vette Life
Long term you will have much more options for hp instead of adding a supercharger.
Really not worth rebuilding or upgrading the ls1/ls6 for the value
