Read this thread with interest as mine are still apart and I'm out of ideas. I have HID+ballast on the low beam and LED on the high beam. I still have the Sylvania bulbs and I'm going to try putting them back into place with no ballast and see if I can get the doors opening and closing again and will take it from there.
But can I get help with this - when you turn the headlights on - the motors are supposed to spin clockwise (as viewed from the top) and the shaft spins CCW (as viewed from the side)?
Reason: Addition
I did the LED swap today am
nd did ALL of the lights. Headlights have much needed more brightness and sight picture than with standard halogen but, the HCM won’t raise or drop properly. Did the flashers upgrade and everything lighting is great with the exception of the motors operating correctly. I think I will try the resistors first but may end up ditching the pop ups if it doesn’t work! I absolutely hate halogen bulbs now that my newer vehicles have LED lights ... My old 2001 C5 deserves modernized lights.
Agree that is the reason I never upgrade from OEM but to each his own and I don't drive that much at night anymore. Read to many post of issues after changing out bulbs.
OK, i was not aware of this problem. I have only owned my 99 vert since fall 2019. I have probably used the headlights less than 5 times, so not a lot of experience in that department. I live in the northeast and car is currently garaged for the winter. I recently replace both hi and lo beams with led. (after a little reading i realized a lot of you only bother to switch out the lo beams. makes sense but i had already bought hi and lo) Anyway, when i finished installing the bulbs and was done for the day, the lights didn't go down. I said to myself, thats funny, maybe the car has to be running for the lights to retract. This is where my lack of experience with the lights comes in. So i started the car and put the lights down. don't remember if hi beams were on or not. Long story short, if this is going to be an issue, i'll go ahead and install the resistors from Amazon that Dave's 1st Corvette said worked. It looks like the kit will do 2 headlights, so i'm assuming that i will need 2 kits. That sound about right?
