Relocating '99-'00 ABS System for Vortech
Old Nov 1, 2002 | 10:58 PM
MelloYellow's Avatar
MelloYellow
Default Relocating '99-'00 ABS System for Vortech
Anyone have experience or comments on relocating the '99-'00 ABS piece in front of the Alternator? Anything special you need to be careful about? Comments/Suggestions on good ways to relocate it?
It's in the way of the Vortech kit.
Andy is going to get the measurements to see where it should be moved. Just wondering if there is anything special to consider when you start bending tubes and moving that thing around.
Thx!
Old Nov 1, 2002 | 11:55 PM
55SUX's Avatar
55SUX
Default Re: Relocating '99-'00 ABS System for Vortech (MelloYellow)
I never looked where it was located on the 2001 and up. Did they move it to a different location than the 99-00? I know they moved it from the rear to the front in the mid 98 model run when active handling came out but didn't realize they moved it again in 2001. Guess they must have moved it if it didn't create a problem on the 2002 Z06 kit.
Old Nov 2, 2002 | 12:32 PM
MelloYellow
Default Re: Relocating '99-'00 ABS System for Vortech (55SUX)
Yes, it was moved after 98 on the 99 & 00 models.
Then again, move lower I believe on the 01-03's.
Any mechs have comments on moving it around on the 99-00?
Thanks.
To Relocating '99-'00 ABS System for Vortech
