Looking for 3.90 gears????
Old Nov 1, 2002 | 11:07 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Looking for 3.90 gears????
I'm selling my 3.90 gears:
http://forums.corvetteforum.com/zerothread?id=419594
Old Nov 1, 2002 | 11:10 PM
chuckster's Avatar
chuckster
Default Re: Looking for 3.90 gears???? (OliverM5)
Oliver, if they whine they were incorrectly built period! Send them back to whoever you bought em from and have them do them right. Has to be a warranty...Where did you get them?
Why should you take the financial hit because of someone elses incompetence...my 4.10's are quiet as a mouse up to 120mph so far..
Old Nov 2, 2002 | 02:58 PM
OliverM5's Avatar
OliverM5
Default Re: Looking for 3.90 gears???? (chuckster)
Chuckster, they reason they whine is because I had the gears put in the carrier, then I had them dissassemble the carrier internals and put it back together again (old casing was bad so I bought a new one and swapped in the same internals)........
anytime you do that, the gears will not fall into the same exact meshing pattern and may produce a little whine on light load......nothing very bad, just mildly annoying......other than the noise, they run like a raped ape.....
Old Nov 5, 2002 | 01:04 AM
OliverM5's Avatar
OliverM5
ttt
To Looking for 3.90 gears????
