Soft brakes
Old Mar 15, 2019 | 05:35 PM
C5wilts's Avatar
C5wilts
Default Soft brakes
Had my brakes bled cause they were very sponge so few weeks go by they get that way again I bled them today and had a big air pocket any ideas what could be causing this?
Old Mar 15, 2019 | 07:00 PM
JR-01's Avatar
JR-01
How many miles and years are on the pads and the brake fluid?
Old Mar 15, 2019 | 07:09 PM
gimp's Avatar
gimp
Brake pedal was firm, then over time became less firm, and you noticed a large amount of air in the system?
That doesn't sound good. I would inspect for a leak, first. Failing that, perhaps the master cylinder is not properly sealing? Also, was the cap tight?
Old Mar 15, 2019 | 08:25 PM
C5wilts's Avatar
C5wilts
180,000 on the car not sure about the pads didn’t look very old master cylinder cap tight no drips in drive
Old Mar 15, 2019 | 08:31 PM
JR-01's Avatar
JR-01
Seals could be bad in the calipers. Look for evidence of leakage. Sometimes slightly warped rotors will pump air in if the seals are bad. Do the brakes pulsate?
Old Mar 17, 2019 | 12:34 AM
Moved to C5 Tech.
Old Mar 17, 2019 | 01:47 AM
hgoodwiniii's Avatar
hgoodwiniii
Has to be a leak somewhere; Whenever you figure that problem, you might want to think about braided brake lines; I just put some on my C5 and took a road trip in it today and the freaking brakes are awesome, as hell. They are very tight and very responsive.
Old Mar 17, 2019 | 11:47 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
could be your not getting all the air out of the ABS system, best to do a Auto bleed with a Tech 2 ???????
https://www.corvetteforum.com/forums...h-2-bleed.html
Old Mar 19, 2019 | 06:02 PM
Bill Dearborn's Avatar
Bill Dearborn
Could also be a problem with one of the bleeder screws not sealing properly. As the brakes are applied and released a little air can be pulled into the caliper.
Bill
Old Mar 19, 2019 | 09:25 PM
C5wilts's Avatar
C5wilts
Haven’t had any issues since bleeding them hoping it was residual air in the line fingers crossed.
Old Mar 20, 2019 | 10:28 AM
Robrote's Avatar
Robrote
Rubber hoses can also do that. If they are originals, I would swap them out.
Old Mar 21, 2019 | 11:05 AM
redzg's Avatar
redzg
If you’re getting a repeat soft pedal and no signs of leakage, I’d bet on master cylinder seals starting to leak internally. For the OEM master a Delco or NAPA kit would do well for little cash - as long as the bore is still smooth and straight.
To Soft brakes
