2 tracking outing's same out come.. 2yrs ago on 3rd pass I break the R/H shaft on 2-3 shift, this past weekend on 3rd pass I break the L/H shaft at the line...
Both time with aftermarket upgrade shafts!!!!
Leaving off idle except the last time I went to leave at 2500rpm
First track event car was on 305-35-19 NT05R's Second track event car was 305-45-17 M/T drag radial R's
Cars makes 716rwhp & 699tq 6 speed
At $1500 for repairs these track days are becoming expensive!!!!
With drag radials, youre probably dead hooking a 3200 lb. car with those spindley axle shafts. Are you snaping the joints or twiisting the axles. ?? Aint gonna'. work. Oh,, you might get away with it for a while,, but they are a twistin''...Paint a white line on them and keep an eye on the line. Try to upgrade the axles, or like said above,,,hang a different rear end under it.
I haven’t had time to call them, broke the car last Sunday and then left town on Monday. I will call them Monday and see what they say plus these are their latest and greatest. Probably put less than 500 street miles and then 3rd pass snap still shocked it was the drivers side
A drag radialis designed to dead hook and has a stiffer sidewall so it shocks the drive train harder. A bias ply is designed to spin a little at the hit and the sidewall is more flexible so it softens the hit.
Most often when a shaft breaks, it breaks clean, like you’ve described. I’ve used 300M, 500M, and the trick ones from Eaton that come with their posi unit. I’ve snapped them all.
The only ones ones I haven’t snapped, are the OEM C6Z shafts. Not saying they can’t break, but this is just my experience with hundreds of passes in both manual cars and auto cars.
What clutch are you using? That also plays into how hard you can launch the car.
Being cautious, start at 2000rpm and work your way up to 3500 or so depending on your comfort level. 18psi in your slicks. That’s typically way too much pressure, but when getting used to a slick, it’s always better to have them spin too much vs not enough.
This video shows a relatively weak launch for the combo. This car is using OEM C6Z shafts ($80) on both sides. 27” tall slicks with about 900rwhp.
The McLeod RXT is a great clutch. That’s what is in the C5Z in the video. It takes a beating and keeps going. He launches at 4000 and 60’ in the high 1.3s.
