Water Pump Replacement
Old Mar 16, 2019 | 12:41 PM
2003ernie's Avatar
2003ernie
Cruising
Default Water Pump Replacement
Good Day...Gentlemen,
...trying to put together my C5. Was overheating and I decided it was time to replace the water pump, radiator, hoses etc. On the casting the water pump there is what I think a part number of 12600470. When I search on the various automotive parts places I cannot find an exact match. Got any ideas or recommendations on this replacement?
Old Mar 16, 2019 | 01:44 PM
feeder82's Avatar
feeder82
Did mine last year, used AC Delco 19195105
Old Mar 16, 2019 | 01:48 PM
STRMLNE's Avatar
STRMLNE
Just had mine done.
https://www.gmpartsdirect.com/oem-pa...p-kit-12681185
Old Mar 16, 2019 | 02:12 PM
2003ernie's Avatar
2003ernie
Cruising
Default Water Pump
Thanks for the input on the GM Water Pump. Was it assembled in the U.S.? From what I have seen on various sites prices for the pumps vary from a low of $75 ( Gates ) up to over $200 ( AC Delco ) just for the pump only and possibly gaskets. Prices are all over the place...bottom line is fit and finish...
Originally Posted by STRMLNE
Old Mar 16, 2019 | 02:54 PM
Ed Ramberger's Avatar
Ed Ramberger
The same kit is on Amazon for under 100$
Old Mar 16, 2019 | 02:57 PM
STRMLNE's Avatar
STRMLNE
link?
Old Mar 16, 2019 | 03:11 PM
2003ernie's Avatar
2003ernie
Cruising
Thanks...Ed,
...will check on Amazon for the kit. Price is more in the range compared to Rock Auto and Summit that I have looked at...
Old Mar 16, 2019 | 03:33 PM
Ed Ramberger
link?
I just googled the PN in the post2 and is supercedes to the one in post 3. Very easy to find.
Amazon Amazon
Old Mar 16, 2019 | 03:45 PM
STRMLNE's Avatar
STRMLNE
You’re smarter than me, Ed. Cheers.
Old Mar 16, 2019 | 03:53 PM
Ed Ramberger
LOL Trust me sir, I learn EVERY day.
Old Mar 16, 2019 | 05:36 PM
STRMLNE's Avatar
STRMLNE
What’s the difference between the kits?
Old Mar 16, 2019 | 05:44 PM
aaronc7's Avatar
aaronc7
ACDelco 251-744: OEM replacement that uses the newer style water neck with separate thermostat. Made in USA I believe
ACDelco 252-846: "Professional" series that's made overseas, a lot cheaper. Uses older style water neck with built in thermostat. I bought this one and it works well. Only issue I've had is the bracket on it caused my blower setup to be misaligned slightly... was not an issue with the autotensioner when I was NA.
Old Mar 16, 2019 | 09:45 PM
Ed Ramberger
Interesting - looked them both up - one is literally 2x more expensive. Confusing because on Amazon, both pics look the same.
Old Mar 17, 2019 | 05:26 PM
STRMLNE's Avatar
STRMLNE
I stay away from Chinese parts. The kit from gm direct is cheap all things considered. If another option is considerably cheaper, it’s probably too good to be true.
Old Mar 17, 2019 | 09:01 PM
My Vette Life's Avatar
My Vette Life
Got my acdelco from summit, paid about $100 for it.
Turned out i only needed to swap out gasket. Since the old one blew out but just did the whole thing.
To Water Pump Replacement
