fuel tank
Old Mar 17, 2019 | 06:58 PM
orca13's Avatar
orca13
Default fuel tank
ok guys some where on here there was a post about a fuel tank issue on some 2004 C5's. My vin number falls in between the numbers that was involved. Don't know if it was fixed. If not what should I do. I haven't had any issues while filling the car up. What do I look for???
Old Mar 17, 2019 | 11:15 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Contact your local dealer with you VIN, and ask whether the repair was done - it should be in the national database if done.
You're not going to be able to "see" the issue -- it was a problem at the cross-over tube between the tanks, way up at the top of the tanks.
Old Mar 17, 2019 | 11:29 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
https://www.corvetteforum.com/forums...-question.html
Old Mar 18, 2019 | 12:57 AM
Moved to C5 Tech.
To fuel tank
