Harmonic Balancer
Old Mar 17, 2019 | 01:21 PM
helives4u2's Avatar
helives4u2
Default Harmonic Balancer
Hello out there in Corvette land, I was wondering if anyone is using the Fluidampr P#740121 on their Vette? My Z has the wobbles at 15yrs 22k miles and needs to be replaced. So thankful for this forum... I will be using the ARP bolt also...thanks again
Old Mar 17, 2019 | 01:43 PM
Grandpa1's Avatar
Grandpa1
Sounds like you read the forum!
I used the Powerbond HB when I had mine changed because that's the one that was mostly recommended by members.
I do not know about the one you asked about.
Good luck!
Old Mar 17, 2019 | 04:01 PM
Josephu's Avatar
Josephu
ATI fluid damper is Hi dollor. If you have the money,, go for it .. Its the Best. But for the average guy who only street drives his car,,,get the Powerbond/Dayco. It is also SFI approved. PB1117N-SS-Race. Summit or Jegs,,about $260 bucks. It will also be the last one that you will buy.
Old Mar 17, 2019 | 04:40 PM
pjdbm's Avatar
pjdbm
I used the Powerbond with ARP bolt but I hear good things about the Fluidampr
Old Mar 17, 2019 | 07:36 PM
bwill03z's Avatar
bwill03z
what is the difference between the Powerbond you mentioned and the Powerbond p/n PB1117N that you can get for under $100 bucks?
Old Mar 17, 2019 | 07:45 PM
1blkc4's Avatar
1blkc4
I just got doing my hb I used the regular one pb1117n (rock auto) with ac delco bolt which is just fine unless super charging or highly modded than go with fluidampr . Its really not that bad too do .
Old Mar 17, 2019 | 08:00 PM
bwill03z's Avatar
bwill03z
I got this one with an ARP bolt for my cam swap soon, that’s why I was wondering the differences.
Old Mar 17, 2019 | 08:25 PM
Josephu's Avatar
Josephu
The $100 dollor Powerbond is a stock type replacement balancer. Looks just like the one that you are taking off. People have had them start to wobble again. The SS Race is a whole different design. It has a large snap ring to hold the outer ring from moving out of location. SFI approved, and comes off with a 3 bolt puller instead of the hook type puller. $100 dollor one will work fine . Just dont know for how long. I figured what do you get for a 100 bucks today??? Do it once,, and forget about it.
Old Mar 18, 2019 | 06:35 AM
Grandpa1's Avatar
Grandpa1
I have not seen any story about the cheaper Powerbond HB wobbling at all. Ever.
Old Mar 18, 2019 | 09:11 AM
pjdbm's Avatar
pjdbm
I have not either and I keep up with as mush HB discussion as possible. If anything, its too early to call.
Old Mar 18, 2019 | 08:38 PM
Bobtam's Avatar
Bobtam
I have a Trick Flow balancer from Summit on my Z. My installer highly recommends them.
Old Apr 5, 2019 | 02:30 PM
aheldt88's Avatar
aheldt88
Cruising
https://www.summitracing.com/parts/p...stionsanswers/
So is this the one that you recommend? My engine is pretty much stock, but this is something that i really do not want to have to do again.
Old Apr 5, 2019 | 04:26 PM
Smoken1's Avatar
Smoken1
Yes, this one
To Harmonic Balancer
