Is it possible to over fill the automatic trans?
Old Mar 21, 2019 | 11:02 PM
lunaticfringe007's Avatar
lunaticfringe007
Default Is it possible to over fill the automatic trans?
Curious if it can be done. I thought they are filled at a hole on the top side of the tranny and when the ATF runs out it is full. So i dont think it can be overfilled.
Old Mar 22, 2019 | 12:16 AM
jrprich's Avatar
jrprich
https://www.corvetteforum.com/forums...post1598221610
Old Mar 22, 2019 | 08:01 AM
lunaticfringe007
So you cant overfill it then. you could under fill it if you did it cold but the fact that the fluid runs out of the fill hole when it is full means you cant over fill it. Right?
I ask because when a brought home the car after I bought it and parked it in the driveway, the next morning there was a small amount of ATF on the ground. The same the next day after I drove it. The outside temps were around 70 and the trans temp was up to 210 (a little high for me). I cleaned up the area and put a drip pan under it. No more drips. So I took it back to the place I bought it from and they took it to a mechanic. It did not drip again the morning I dropped it of. The mechanic cleaned up the area and did not observe any other drips. The mechanic thinks the trans was over filled and the ATF found a way out? Not sure I buy it. I drove it a bit yesterday and could not get the trans above 185 deg. But this morning no drops on the ground or under the car that I could see.
I planned to take it to a local trans shop Monday to have the trans drained, filter replaced and refilled. I will have that mechanic take a closer look at that time also.
Old Mar 22, 2019 | 08:09 AM
sstonebreaker's Avatar
sstonebreaker
Just speculation here, but I wonder if you can get air in the lines like when you fill the cooling system? Like maybe they didn't fill the car on a level surface?
Old Mar 22, 2019 | 08:46 AM
lunaticfringe007
That's a possibility. I am not driving it until I take it to get the trans serviced. Going to get the Diff fluid drained and refilled also.
Old Mar 22, 2019 | 11:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its just about IMPOSSIBLE to over fill the A4if you follow the service manual procedures to drain and fill. Its VERY POSSIBLE to under fill it..
To correctly fill it, you have to fully warm the engine drivetrain put the car level on a lift "CAR LEVEL",
WITH THE ENGINE RUNNING remove the fill plug on the drivers side of the trans. You add fluid till it runs out of the fill hole. Reinstall the plug "WHILE THE ENGINE IS RUNNING!!!".
IF,,,,,,, SOMEONE REMOVES the plug without the engine running, the trans will puke out a LOT of the required fluid fill and it will be low enough to damage the trans if operated for a long period of time.
I guess if you lifted the car at a steep angle from the drivers side, you COULD force in more than it needs but, that's about it.
BC
Old Mar 22, 2019 | 11:11 AM
lunaticfringe007
BC
So the diagnosis that the trans was overfilled is not likely? I wonder why the dripping stopped? Hmmm..going to require mor investigation.
Old Mar 22, 2019 | 11:22 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! LOL!
If it were ME, I would clean the entire bottom of the car/drivetrain. Take the car for a drive and then reinspect and see if there are any leaks.
There is a portion of the torque tube bell housing to differential housing where the fluid can leak out. Take a special look in that area, If it leaks ATF there, the trans output rear seal is leaking
Bill
Old Mar 22, 2019 | 11:30 AM
GCG's Avatar
GCG
...I planned to take it to a local trans shop Monday to have the trans drained, filter replaced and refilled. I will have that mechanic take a closer look at that time also.
Make sure they are aware of the correct fill procedure. Some transmission shops have never worked on a C5, or might not be familiar with the correct procedure.
Old Mar 22, 2019 | 12:19 PM
lunaticfringe007
I was going to do that. Thanks for the suggestion.
Old Mar 22, 2019 | 02:04 PM
bighank's Avatar
bighank
Default You can overfill the trans but you probably have a leaky line
You should fill the AT when it is hot and not cold. Instructions elsewhere on the forum. I had a leaky line going from the trans to the cooler in the radiator, If ATF is not leaking at the trans it could be leaking from one or both of the lines to the radiator.
Old Mar 22, 2019 | 02:30 PM
lunaticfringe007
Other than not having it level when you out the ATF in it, how do you overfill it?
Old Mar 22, 2019 | 08:15 PM
crf450x's Avatar
crf450x
Based on the directions above, doing that procedure with the trans cold would result in it being over filled.
I’ve never dealt with one of these. But I’ve filled countless transmissions through a dipstick tube. Same concept as far as temperature.
Old Mar 22, 2019 | 08:51 PM
Deliso1's Avatar
Deliso1
Sounds like the output shaft seal to me. I’m having the same problem.... only leaks when the car has been sitting awhile and temps are colder outside.
Old Dec 3, 2020 | 11:57 AM
Avispa's Avatar
Avispa
This^^^ and if the leak is vehicle speed or engine speed related, you can diagnose it further by driving in 1st gear to the same engine RPM you see at 70 MPH in top gear.
To Is it possible to over fill the automatic trans?
