C5 corvette starting
Old Mar 26, 2019 | 06:21 PM
thevelvetglove's Avatar
thevelvetglove
Default C5 corvette starting
When I first got my C 5 corvette it would start with a quick flick of the key. Now it turns over several times before it starts. I have new plugs and wires so I am thinking it is not pre priming with gas.
So how can I check this. Thx
Old Mar 26, 2019 | 06:47 PM
gimp's Avatar
gimp
Attach a fuel pressure gauge to the fuel rail and check.
Old Mar 26, 2019 | 07:19 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Agree with gimp !!...get a fuel pressure gauge and see if pressure drops more than 5 psi after 1 minute after you read the priming pressure...pump will prime for 2 seconds then turn off... fuel pressure should be 55-62 psi...these numbers are for an ‘01...your ‘01 is probably the same !!
Old Mar 26, 2019 | 07:27 PM
STRMLNE's Avatar
STRMLNE
what happens if you turn the key to #2 and wait for the fuel pump to prime, and then start it? Does it fix the issue?
Old Mar 26, 2019 | 07:40 PM
C5 Diag's Avatar
C5 Diag
Exactly !!...OP just has to be “quick on the crank” before the pump shuts off...LOL !!
Old Mar 27, 2019 | 12:01 PM
thevelvetglove
Ok thanks I will check start position two and let you know. I am gesssing I can rent a rail fuel pressure gage.
Old Mar 27, 2019 | 05:45 PM
thevelvetglove
nn it did not fix the problem
Old Mar 27, 2019 | 05:54 PM
STRMLNE's Avatar
STRMLNE
c5 diag is very knowledgeable. Hopefully he chimes in again to help you. Does sound like a fuel pressure issue.
Old Mar 27, 2019 | 07:49 PM
C5 Diag's Avatar
C5 Diag
What I should have asked first is how much longer does it take to start ??...does this happen on first start up of day ??...if you drive the car until it reaches operating temp and you shut it off does is it still a longer crank ??...if I were you I’d take it to an auto store and have them test the battery...the injectors and especially the coils take a lot of juice on a cold start up...the car’s sensors need full voltage too...ANY driveability issues need the battery to be checked first !!
Old Mar 28, 2019 | 07:51 AM
bahamasair's Avatar
bahamasair
Try turn the key to position 2 so it primes the pump. Then turn off and do it 3 more times. If it starts normally you have a fuel pressure problem.
To C5 corvette starting
