Headlight motors
Old Mar 26, 2019 | 08:29 PM
vette-a-long's Avatar
vette-a-long
Default Headlight motors
Left front turn indicator, blinking fast on the dash, front left light out. I remove the bulb from the holder, bulb is still good but the connector part of the bulb that you insert is showing signs of corrosion. I put a new bulb in and get the same fast blink. Remove the bulb put some dielectric silicone compound on the bulb connectors. Insert the new bulb, same fast blinking. I then remove the bulb, put a regular screw driver into the bulb holder, a few motions with it in an attempt to clean off the connectors. Put the new bulb back in and it now blinks at the normal pace and is functioning properly. But now both of my headlight doors do not work. I fear that my error was putting the screw driver into the receptor in lieu of sand cloth and I have shorted something out. Both '10' fuses look good. Is there a relay or some other electrical control that I may have fried?
